Tow weight of 26M heavily laden for remote area cruise
Posted: Sat Oct 13, 2012 6:17 am
On the the Australia board of this forum there has been some recent discussion about choosing a tow-hack/tow-beast and just how much load your
might put on a tow vehicle.
When I bought my 2007
,I also bought a Totyata Kluger based on the factory specs of the
and its trailer thinking I had a few hundred kilos to play with for gear and provisions.
Bad (expensive) mistake!
When I put it the modestly loaded
(on its original steel trailer) over a weighbridge not long after I bought it weighed in at 2,300kg. This exceeded both (a)the Mac trailer aggregate load rating (just over 1,905 kg for the then painted steel) trailer and (b) the Toyota Kluger V6 towing capacity which was only rated to tow 2,000 kg. Because I wanted to travel widely with my
This created both legal and insurance risks.
I needed the capacity to carry provisions and spares for remote areas, so I upgraded the tow vehicle to a Toyota Landcruiser rated to tow 3,500 kg) and, after an abortive attempt to upgrade the carrying capacity of the original trailer, I eventually purchased a Venture Aluminium trailer rated to an aggregate load of 3,200 kg. I figured that ought to be enough!
It was enough and the new combination has generally performed well. However, I thought it might be of interest to forum members just how much a boat, trailer and tow vehicle can weigh when heavily laden with provisions, spares and all the other stuff needed for long distance travel travel to a remote part of the world.
At the time of weighing, the boat was packed as for trip: on board were all anchors and chains, safety gear, Waeco50 ltr fridge empty), icebox (empty) and boat spares and tools, and usual galley and miscellaneous stuff for extended cruising. In addition the 150 ltr water bladder on boat was full, 2x50 ltr fuel tanks about 1/2 full,
The following had been offloaded from boat to the car prior to weighing: 2x64W solar panels, 1x10 ltr can of fuel, 1x 1, 000kva generator, and fridge battery which had been off loaded from the boat to the car, and about 60 kg of food, ice, clothing and bedding.
The car's 138 ltr car fuel tank was near empty when it was weighed, but the car was loaded with everything else for the trip (plus above from boat), including crew (67 kg + 96 kg) heavy duty jacks, 32 kg rubber duck dinghy and miscellaneous spares of all kinds.
Here are my actual weighbridge statistics (actual weights after our 8,000 km Lake Argyle Trip):
Car plus boat total weight = 5,720 kg (12,610 lb)
Trailer and boat aggregate weight (detached from car) = 2,660 kg (5,864 lb)
Car weight minus towball (difference from above) = 3,060 kg (6746 lb)
Car weight with crew and towball weight included = 3,320 kg (7,320 lb)
Trailer Tare Weight (not including spare wheel) = 440 kg (970 lb)
Towball weight = 3320-3060 kg = 260 kg (573 lb)
Towball weight as % trailer gross weight = 9.8 %
Boat plus spare trailer wheel plus gear = 1,820 kg (4012 lb)
It just goes to show that all those little bits n pieces add up...
