Dagger board length?
Posted: Mon Nov 05, 2012 4:34 am
by padge
does anyone know the length of a 26M Daggerboard?
It dropped while towing home last week leaving a nice white line on the road. :(
I can repair it myself but want to get the dimensions correct
Thanks
Re: Dagger board length?
Posted: Mon Nov 05, 2012 7:42 am
by Crikey
This sites 'M' manual states that you should never let the daggerboard drop more than 57" below the surface of the deck. When it is retracted up to the level of the deck the bottom of the foil is just about flush with the hull bottom, therefore the difference between 57" and the keel opening, plus 57", should give you the original length of the DB.
Sorry, too bloody cold to go outside and measure mine!
At least the local council didn't have to pay for painting the new bike lane.. :P
R.
Posted: Mon Nov 05, 2012 9:55 am
Hmm.. I'm surprised it dropped down. Mine has a cable under the dagger on the trailer to catch it if it were to drop.
Posted: Mon Nov 05, 2012 10:11 am
Cant you measure the thickness of the whiteline, the distance home, and divide the resultant volume by the density of FG and buy that much FG replacement??
Im an experimentalist, in theory....
Posted: Mon Nov 05, 2012 10:23 am
by Buell_S1W
Hi, my OEM daggerboard is 69.5 inches. You could add an inch to this and still be safely inside the trunk depth.
Posted: Mon Nov 05, 2012 3:30 pm
by Mac26Mpaul
If the boat is not in the V block all the way, the daggerboard will be behind the safety wire which stops it from falling down on the road. Probably pay to put a second line in (just a bit of rope) to save if from happening again.
Posted: Tue Nov 06, 2012 6:34 am
by padge
Catigale wrote:Cant you measure the thickness of the whiteline, the distance home, and divide the resultant volume by the density of FG and buy that much FG replacement??
I tried but Dodging the 70Mph traffic made it difficult
Thanks for all the sensible help :D
Posted: Thu Nov 08, 2012 5:29 am
Padge...I'd be interested in seeing the damage repair cycle pictures on the DB...I'm doing more and more FG repair so want to learn these skills..
..and no more snarky useless comments, I promise
:D
Posted: Thu Nov 08, 2012 10:04 am
by K9Kampers
It jus wont be th same without yer useless snarkiness!! (or iss it snarky uselessness... i always mix the two up!)
:wink: :D
Posted: Thu Nov 08, 2012 3:03 pm
by Highlander
RussMT wrote:Hmm.. I'm surprised it dropped down. Mine has a cable under the dagger on the trailer to catch it if it were to drop.
I always drop mine onto the cable & then recleat the d/b line
