Raymarine EV-100 Wheel autopilot install
Posted: Sun Sep 29, 2013 10:36 pm
Because this particular autopilot is brand new at the time of writing and there are few if any other install logs on the Internet, I figured I'd document my installation.
EV-100 Wheel is a kit containing:
1) ACU-100 motor controller
2) ST4000+ Wheel motor
3) EV-1 9-axis sensor head (3 3-axis sensors, heading, compass, and gyro)
4) p70 autopilot controller instrument
5) All necessary SeaTalkNG cables and connectors to complete the installation.
You may consider trying to get this autopilot with the p70r instead of the p70: It's got a rotary knob instead of +/- buttons, and one additional feature: Power steering mode. You can use the rotary knob as a wheel.
Testing:
I always bench test everything before I do anything else, so I got the system up and installed using the kit cables, and everything worked fine.
Wiring:
The most significant issue with the Raymarine is that it's connectors are SeaTalkNG rather than standard NMEA 2000 (now apparently called "DeviceNet"), and the rest of my boat install is NMEA 2000. I'd originally decided I'd make a backbone adapter cable to adapt the SeaTalk "half" of the network to the NMEA half, but it turned out to make more sense simply to make NMEA 2000 adapter drop cables.
Three devices had to be adapted: The ACU-100, the p70, and the EV-1.
The ACU-100 is easy: Since it has a wire-in header rather than a plug, you can just wire in a chopped NMEA 2000 cable. No problems there.
With the p70, I just took the bare wire SeaTalkNG cable intended to be wired to the ACU-100 and wired it to a male Garmin field installable connector to make a SeaTalkNG to NMEA-2000 adapted drop cable.
The EV-1 actually has an NMEA 2000 connector on it, but the manual warns not to use it unless you have an ACU-200, so I figured better safe than sorry and just made an adapter using a chopped SeaTalk cable and the same Garmin field installable connector.
Garmin field installable male connector: http://www.westmarine.com/webapp/wcs/st ... tId=435902
I adapted the way my network was wired to accommodate the fact that I have more devices on the bus and that they're all over the boat. Previously, I used drop cables everywhere and had the entire "backbone" in the battery compartment made of T-connectors and terminators.
Before cutting any holes, I ran all the cables to the mount locations and tested the system again where it would be installed, with the chopped up SeaTalkNG cables, and with the changes to my NMEA 2000 backbone. Everything worked fine.
Mounting:
I started with the wheel motor because I knew it was going to be a bitch. It took me two days, a gear puller, WD-40, and the help of a maintenance man to get the wheel off (I guess I just wasn't willing to hit it hard enough). Once the wheel was off, attaching it to the wheel was a piece of cake. After putting the wheel back on, I fixed the motor in place on the port side with a 6" Shaeffer 316 stainless strap that I'd bent into a bracket because the motor is an odd size and the include helm pin only works on a column mount.
To accommodate the p70 in the helm, I converted the cable I'd already run to the helm to connect to the chartplotter and turned that into one end of the bus. This was simple: I just put two T-adapters on the end with a terminal resistor, and then ran a 1' drop cable to the chartplotter and the SeaTalk adapter to the p70 control head right next to it. In the battery box, I removed the same gender terminator and moved the former drop cable to the end of the the T-bus, which made it a backbone cable. I was very happy I didn't have to run a second 15' cable to run another device.
Because I'm going to get a NavPod rail and backplates in the future, I didn't want to cut a hole in the helm, so I mounted the p70 in the smoke cover plate which is easily replaced.
Autopilot head and motor:
For the EV-1, I decided to mount it as close to the center of rotation for all three axes, which is next to the daggerboard below the forward dinette seat. The EV-1 is supposed to work anywhere on the boat as long as it's level, but I think I'll get the best dynamic range here. It's also very hidden and some of the most vertical fiberglass on the boat. To mount it, I drilled holes for two machine screws into the head fiberglass that were 2" long, then pushed the EV-1 bracket onto the two loose screws from under the dinette, threaded on hex nuts as far as I could, and then screwed them down from the head side. I'd tested the nuts earlier and found that 8-32 machine screws and nuts were the perfect size to fit into the bracket such that the nuts couldn't turn.
The sensor can be rotated in the bracket to any heading direction, and has to be aligned with the longitudinal axis of the boat. I used my iPhone compass to match the heading reading of the sensor head before snapping it down. We'll see how close I was in sea trials.
This is the sensor head, located under the forward settee:
For the ACU-100 control head, I wanted to minimize power line lengths, use the 15' stock motor cable alone if possible, and hide the unit. It needs to be mostly vertical as well according to the installation instructions. I mounted it on the port side under-galley storage aft liner, just forward of the aft berth. In this location I was able to run the motor power cable down the helm, along the cable bundle to the stern, down through the port upper bilge, and through an existing hole to the ACU-100 with about 1' of cable to spare. It's only two feet from the battery box as well so the power connector was very short, and it's right next to my NMEA-2000 backbone so that connection was very short as well. I think it's an ideal location.
Inside the storage it's in otherwise wasted space:
The commissioning is pretty simple although they want you to input the time the autopilot requires from rudder-stop to rudder-stop, but there's no apparent way to make the autopilot do this procedure. I'll call raymarine tomorrow to ask them how they propose calculating that number. I suppose I could just put 12V on the motor until it hits one stop, then reverse the leads and calculate the time until it hits the other, but it seems like something the pilot should be able to do.
So everything is installed, mounted, and working. I'll post an update after sea trials this weekend.
Testing:
Wiring:
Mounting:
