Folding steering wheel
Posted: Wed Oct 30, 2013 4:09 pm
by innervations
Has any installed a folding steering wheel on an
or
If have searched the mods and forums but cannot find any mention.
http://www.chsmith.com.au/Products/Lewm ... heels.html
They are expensive but the larger wheel would make steering feel much better.
Re: Folding steering wheel
Posted: Wed Oct 30, 2013 5:10 pm
by Highlander
u can p/u A 20" OR 22" WHEEL for about $90. a lot cheaper & not too big to get around
Posted: Wed Oct 30, 2013 5:27 pm
by Matt19020
I have a larger wheel....If you can afford a folding one go for it...
My issue is I can not open fuel lockers fully to fill tanks...not a terrible problem but a little pain in the a$$
Posted: Wed Oct 30, 2013 8:23 pm
by innervations
Thanks guys for the suggestions. Mat19020 that wheel looks great. Must be easier to steer that using the stock. What diameter is it?
Posted: Wed Oct 30, 2013 8:57 pm
by bartmac
Good idea of a folding wheel BUT....geez bit of money
Posted: Thu Oct 31, 2013 12:26 am
by SKIPPER2C
"Matt19020"]I have a larger wheel....If you can afford a folding one go for it...
Matt I did a mod that might work for u.
Posted: Thu Oct 31, 2013 5:53 am
I looked into a folding wheel for my last boat, and when I got finished choking on the price, I pulled the nut and stored the wheel on the rail when spending extended time on the boat. Gotta be careful about dropping it over the side, so I'd tether it with a line when it was still in the cockpit, then strap it to the rail tightly. Belt and suspenders. It was a big wheel, and even the stock destroyer wheel was a lot of money. The folder was thousands.
I only see a nut there, so it should be easy to pop it off. Free, too. Just watch the key. You can buy a knurled nut for easy removal without tools, but I kept the nut on mine just tight enough that I could remove it without tools. Also free.
Posted: Thu Oct 31, 2013 7:16 am
by reastmure
Doesn't look like it would be compatible with an auto pilot. In fact you could pick up an auto pilot for less cost . Love my auto pilot! It doesn't mind handling the smallish Mac steering wheel
Posted: Thu Oct 31, 2013 12:18 pm
by yukonbob
How does the larger wheel do with putting extra tourque on the steering?
Posted: Thu Oct 31, 2013 4:42 pm
by Matt19020
innervations wrote:Thanks guys for the suggestions. Mat19020 that wheel looks great. Must be easier to steer that using the stock. What diameter is it?
Not sure about easier...I never even used the stock wheel. I put this on before I put it in the water for the first time
This is from an earlier post:
http://www.macgregorsailors.com/forum/v ... lit=+wheel
I put a 28" wheel on but If I were to do it again I would use a 26" for better tank clearance and walk around room... check the below link, mid page for pictures
http://macgregorsailors.com/forum/viewt ... eel#p78824
Posted: Thu Oct 31, 2013 4:44 pm
by Matt19020
SKIPPER2C wrote:Matt I did a mod that might work for u.
Thanks Skipper that is a great idea..I may look into that over the winter to see if it will clear the wheel
Posted: Thu Oct 31, 2013 4:49 pm
by Matt19020
yukonbob wrote:How does the larger wheel do with putting extra tourque on the steering?
Not sure...I believe I saw something on the dismantle of the existing (stock wheel) and it stated that they (teleflex) did not recommend increasing wheel size...
Posted: Fri Nov 01, 2013 12:00 am
by Boblee
When we first got the boat was going to try and put a hinge arrangement at the bottom of the pedastal but quite happy now with the standard wheel it seems to grow on you.
Posted: Fri Nov 01, 2013 11:02 am
by mastreb
I can't imagine climbing around a wheel any larger than the stock one. The cockpit is already too cramped. I will say however that it's just BARELY big enough for the Raymarine wheel pilot.
Posted: Fri Nov 01, 2013 9:35 pm
That's because God had to put a big body around that big heart, Captain.
