Modifying My MRS - Should I Go With Line or Cable BStays?
Posted: Fri Mar 07, 2014 10:15 am
by Saxacussionist
The baby stays are a "guide", so some give shouldn't be a problem. Having said that, my X came with metal baby stays. If you have lines, I really don't see a reason to change them.
I have a 26S with the older MRS and would like to upgrade to the M style. BWY no longer sells the kit due to liability reasons but will sell me the individual parts. All I really need is the winch, block, mast bail and a few shackles. They also offer the cable baby stays and I am wondering if it is worth the cost. I have been using baby stays made from 5/16 line and they are ok, however, there is a bit of give to them that makes me nervous now and then when I have some cross wind or have to park on a bit of a hill.
What do you recommend?
Thanks for your help!
Brad
Re: Modifying My MRS - Should I Go With Line or Cable BStays
Posted: Fri Mar 07, 2014 10:24 am
by mastreb
Zero stretch line such as dyneema rope would be perfectly fine. You might want to go with snap shackles or pelican hooks as well, because the screw-pin shackles are a PIA. The baby stays are not under much constant tension, but they could be under some shock when things go sideways.
Posted: Fri Mar 07, 2014 11:15 am
by Tomfoolery
I'd do the Dyneema also, or make my own from wire rope, though I have crimp tools and you may not.
The winch is a Dutton-Lainson brake winch, 350 lb capacity. Easy to find retail on the net.
http://www.dutton-lainson.com/proddetail.php?prod=15940
Bail can be gotten from West Marine and others, and of course, BWY. You'll need a block good for at least 500 lb SWL (rope turns about 90 degrees over that sheave), with a wire rope groove, which will work with wire rope or Dyneema, assuming you're using small diameter line on the winch.
Posted: Fri Mar 07, 2014 3:52 pm
by DaveB
Last 5 years we have used 1/8 braided line for baby stays.
Amsteel 1/8 would be much better but the later still works.
I do have all the SS cables for baby stays, just no worth the added weight.
Heaven Bound wrote:I have a 26S with the older MRS and would like to upgrade to the M style. BWY no longer sells the kit due to liability reasons but will sell me the individual parts. All I really need is the winch, block, mast bail and a few shackles. They also offer the cable baby stays and I am wondering if it is worth the cost. I have been using baby stays made from 5/16 line and they are ok, however, there is a bit of give to them that makes me nervous now and then when I have some cross wind or have to park on a bit of a hill.
Brad
Posted: Wed Mar 12, 2014 9:38 am
by Saxacussionist
Thanks for your help. You saved me around $50 for the baby stays and related hardware. I will be buying the parts today from BWY. I could save a couple bucks buying them elsewhere, however, they have been very helpful, provided me with a drawing with all the dimensions and locations for installation. Well worth a few extra $$ to support a company like that...
Brad
Posted: Wed Mar 12, 2014 1:51 pm
by J--
Oh! I finally figured it out!
Mast Raising System!
I thought he was wanting some plastic surgery for the wife!
Posted: Thu Mar 13, 2014 11:30 am
by Saxacussionist
J-- wrote:Oh! I finally figured it out!
Thankfully not needed....
Posted: Thu Mar 13, 2014 11:31 am
by Saxacussionist
I need to be a little more careful with my TLAs...!
