Boom Rivets... 3 Questions
Posted: Sun Apr 20, 2014 6:00 pm
by Matt19020
I need to replace the rivets for the boom gooseneck (very loose).
Should I use Aluminum or Stainless rivets?
Is holding power better with Stainless?
Are dissimilar metals a factor?
Re: Boom Rivets... 3 Questions
Posted: Sun Apr 20, 2014 10:54 pm
by mastreb
The factory gooseneck is riveted on with stainless rivets. Everything else on the boat is aluminum rivets. I presume they wouldn't have have done this if it wasn't important.
Dissimilar metals are a factor, but since the mast is aluminum and the gooseneck is stainless, this problem exists one way or the other.
Posted: Sun Apr 20, 2014 11:33 pm
by kadet
I used aluminium rivets on my loose footed mainsail's outhaul and they pulled out in 20 knots of breeze, they are now stainless and have survived a 25 knot blow. For what that’s worth :)
Posted: Mon Apr 21, 2014 5:22 am
by sunshinecoasting
Use Monel rivets and it is always good to use a corrosion inhibitor paste such as this product http://www.eckcorrosion.com/products.php
Cheers, Dennis.
Posted: Mon Apr 21, 2014 8:05 pm
by Seapup
Another option is stainless self tapping hex head screws.
Posted: Tue Apr 22, 2014 3:37 pm
by jbgibbs99
I use Monel as well.
Posted: Tue Apr 22, 2014 4:51 pm
by Matt19020
Thanks, I will have to see if I can get Monel...I thought you were not supposed to use screws into the mast because of lack of strength..after "tapping" it would really only be held in with Aluminum threads
Posted: Tue Apr 22, 2014 5:54 pm
by Erik Hardtle
I used two Stainless Steel bolts, nuts and washers. I bent the bolt in an open U shape and fed it through where the rivets were. Seems to hold up very well with no slop, and for several years so far.
Posted: Tue Apr 22, 2014 7:20 pm
by DaveB
Tru bolts stainless are best way to go and use plastic washers.
Takes a long arm and tool to get at those nuts inside the mast.
Stainless steel expension bolts also work well.
Monel rivits has same degrade as Stainless Steel in salt water.
Erik Hardtle wrote:I used two Stainless Steel bolts, nuts and washers. I bent the bolt in an open U shape and fed it through where the rivets were. Seems to hold up very well with no slop, and for several years so far.
