Sounds like it's too late, but you really need to do it while the tank is full, preferrably some time before you leave the “contaminated” water. Add the chlorine to the full tank, let it do its job, say overnight at least, then drain it at the ramp when you pull it. More chlorine will require less time for a good kill; less chlorine will require more time.
Any remaining water (and there is always a
lot that stays behind, even if you drain at a steep ramp, I confirmed this with a scope) should then have been sanitized for entering the new waters.
You can't decontaminate effectively unless the ballast is full, and filling it in the “new” waters carries the risk of contaminating it, but, you don't have any other easy options now. (Fill with a hose???)
A tablet will do the job, but requires time (days to a week, or more) to dissolve and disperse, and has the potential to burn (it's a VERY strong oxidizer) the known-not-to-be-chemical-resistant polyester if it is not agitated and moved around enough.
There is less risk going from/to salt water from/to fresh water because invasive species are
usually fastidious and confined to either one or the other of the environments, and not both.
I prefer liquid chlorine ("bleach"), and a quart or litre to a full ballast will give you an effective kill within a day, assuming adequate wave movement for mixing. Unless your tank is severely infected by a thick buildup, then, increase the time and concentration.
Liquid pool shock (sodium hypochlorite) will do as well, use half as much of it. I use a 1l maple syrup HDPE (chemical-resistant) bottle that I pre-fill at home with the liquid pool shock, then just dump the whole container in (which is half full).
I keep the cut-off top of a 2l pop bottle (which fits in the fill hole and prevents splashing of the liquid chlorine in the fill bowl) in a small bucket in the bow storage area to use as a tall funnel. I run a bit of water rinse after the liquid chlorine to keep things neat and tidy. No muss, no fuss, all clean and rinsed, it all goes back into the bucket when I'm done, for the next time.
Also - you don't want to splash that stuff around; if you are prone to, and have the time, then the tablet might be the better choice.
- Brian.
