Madman iSteer autopilot remote for Raymarine
Posted: Sun Jul 27, 2014 11:27 pm
I got the brand new iSteer autopilot remote system for Raymarine autopilots to add to my EV-100 autopilot system. This adds a WiFi base-station that can be linked to your smartphone which with an app then becomes a complete wireless remote for your autopilot, with all of the typical functionality of the autopilot interface. It also includes two wireless key fob remotes that work over 433MHz (like a garage door opener) so you can use it without your iPhone.
http://www.madmanmarine.com/
My primary goal was to get to a system that would allow me to steer the boat safely from inside the cabin while looking out the forward windows or hatch for use in wet weather--essentially to enable a "pilothouse" function.
When I contacted Neil at Madman, he was worried that the iSteer was designed for older Raymarine autopilots that had SeaTalk. My new EVO-1 is the first generation of Raymarine autopilots that is SeaTalk"ng"" only.
SeaTalk is Raymarine's proprietary extension to the NMEA 0183 protocol: It uses their own connectors and a few unique codes, but is otherwise NMEA 0183. SeaTalk"ng" is exactly the same thing to NMEA 2000: Their own connectors and a few proprietary extensions, but otherwise NMEA 2000. My boat has an NMEA 2000 backbone with all the Raymarine devices adapted to NMEA 2000.
I called Raymarine to ask how their SeaTalk to SeaTalk"ng" adapter device worked, and they indicated that it should work just fine with an autopilot remote, as it actually has electronics in it to convert sentences from SeaTalk protocol to the very different SeaTalk"ng" protocol. It's how they adapt their own Raymarine branded wireless remotes to the EV-100.
So Neil shipped me out the iSteer device, and I ordered the SeaTalk"ng" adapter along with a SeaTalk"ng" to NMEA 2000 adapter because my backbone is NMEA 2000 DeviceNet connectors and I adapt all the RayMarine SeaTalk"ng" connectors to that.
When everything arrived, I chopped the SeaTalk cable that came with the adapter and connected it to the bare wires on the iSteer (it's bare wire because it would normally plug into the screw terminals on an older autopilot. This was trivial, as the wire colors all match correctly: Red to red, yellow to yellow, black to uncoated ground.
The SeaTalk adapter looks like a connection block with five ports: A blue one on each end, two white "ng" ports inside that, and a yellow "SeaTalk" port in the middle. If you're using the block in the middle of your backbone, the bone goes in one blue and out the other. You can then use the two white ports for "ng" drops and the yellow drop for your SeaTalk device. If you aren't using the block in the middle of your backbone but instead at the end of the drop, you terminate the two blue ports, plug your seatalk device into the yellow port, and your "ng" cable into a white port where it goes to the backbone. You then cap off the other white port. The adapter comes with all the necessary plugs, terminals, and cables and the instructions explain all this.
I plugged the iSteer chopped cable into the middle yellow connector on the SeaTalk adapter, plugged the NMEA 2000 to SeaTalk"ng" cable into my backbone and into the white connector on the SeaTalk adapter, and put in the two blue terminal resistors in the SeaTalk Adapter's blue ports because I was using this as a drop cable and not part of my backbone.
Powered it on, and voila, everything worked correctly immediately. Connected my phone to the iSteer WiFi base-station and it was immediately able to correctly control the autopilot with no issues.
Big recommend for those of us that want to be able to pilot from inside the boat. Finally there!
