Mast Raising Magic?
Posted: Sun Apr 19, 2015 10:27 pm
by Max Entropy
Re: Mast Raising Magic?
Posted: Mon Apr 20, 2015 5:41 am
by SENCMac26x
That looks cools, but where do you store that massive metal frame once it's up?
Posted: Mon Apr 20, 2015 7:06 am
by Bill at BOATS 4 SAIL
It doesn't look like it would float, so I have one suggestion . . .
"The key to the system is the use of a Spinnaker pole track with a freely moving car"
I hope that Spinnaker pole track is not attached with sheet metal screws or rivets, but with machine screws and a backing plate(s).
I'm thinking of making up a kit to modify a 26X mast raiser into the type used on the 26M, with a brake winch on the mast raising pole, like I use on my 26X.
Would anyone be interested in one of these?
Posted: Mon Apr 20, 2015 7:38 am
by dlandersson
Yup. For an X.
Bill at BOATS 4 SAIL wrote:It doesn't look like it would float, so I have one suggestion . . .
Posted: Mon Apr 20, 2015 8:48 am
by Ixneigh
Looks like a more cumbersome version of the M model mast raising system. Don't see why you need the a frame when cables and a single pole would work.
Ix
Posted: Mon Apr 20, 2015 9:50 am
I saw a production trailer sailor online not too long ago that had a similar system, which folded down and looked like it was just part of the boat when not in use. Don't remember if it had baby stays or not, though. But it didn't look offensive when not in use - it kinda just blended in nicely.
Posted: Mon Apr 20, 2015 9:51 am
Bill at BOATS 4 SAIL wrote:I'm thinking of making up a kit to modify a 26X mast raiser into the type used on the 26M, with a brake winch on the mast raising pole, like I use on my 26X.
I'd considered adding the Dutton-Lainson brake winch to mine, but I already have some large(ish) ball bearing blocks for 5:1 advantage, and there are so many other places I need to spend some coin on that I doubt I'd take it there. But it would be a nice modification.
Posted: Mon Apr 20, 2015 10:39 am
by mastreb
Yeah, I don't see how that's any better than the M mast raising system, and certainly more complex. If something lets go and you're standing at the cabintop winch, the mast is going to hit you.
Posted: Mon Apr 20, 2015 12:09 pm
by EZ
I kinda like the mast raising system on the Hunter Edge. It uses "solid" baby stays that are permanently connected. With this system, the mast is always connected to the deck. Even when moving it from the pulpit to the base. Seems like one of the more safe systems out there.
One drawback is you have to deal with the solid poles always on deck.
Not sure how a Mac can be modified with a similar system though.
Posted: Mon Apr 20, 2015 2:34 pm
by Steve K
Here's one I built.
It is simple, installs in seconds and can be operated from the ground or on the boat. This is great for single handed rigging
https://app.box.com/s/wwre10uq9pbvf54qakoq
(click on the first pic then you can click through them, zoom in, etc.)
The ATV winch is from Harbor Freight and has wireless remote (about $50 on sale). I can raise and lower the mast several times, using just a garden tractor battery. (the walmart one that costs around $15).
Be mindful that this winch has a lot more power than you think. You could bend the mast or otherwise break things by having a shroud/stay hung up on something while raising. PAY ATTENTION!
Otherwise this is a great work saver
Best Breezes,
Steve K.
Posted: Tue Apr 21, 2015 12:32 pm
by 133bhp
Posted: Tue Apr 21, 2015 1:51 pm
by Sea Wind
I agree, for about $120 I converted the X MRS to the M's and it is hard to think of a simpler/more efficient way of doing it - unless you add an electric winch
