Page 1 of 4
Confused about AC
Posted: Mon Jul 27, 2015 5:47 pm
by Dragos Filimon
I cannot figure it out. How many BTU's should I install on A 2002 26X ? I am tempted to go with a small unit - like 5000-6000 BTUs. Is it enough?
Re: Confused about AC
Posted: Mon Jul 27, 2015 7:23 pm
by Billy
That's all you will need. I've used a 5000 btu unit for over 10 years on 2001 X and it will put a chill in the cabin. It gets cold enough to stop the mosquitoes from flying. Best of luck.
Posted: Mon Jul 27, 2015 7:30 pm
by bahama bound
I've seen mine sweat and condensate on the outside in August ! 5k btu running on a Honda 1000
Posted: Tue Jul 28, 2015 6:58 am
by vkmaynard
5,000 BTU AC with the "Billy Box" & rear window is the most awesome system for an X. Looks factory and the extra seating is in constant use either for a "window bar" or to sit on . Easy to step over like an M.
Victor
Posted: Tue Jul 28, 2015 7:44 am
by Dragos Filimon
Thank you very much! That answers my questions. Another month or so and it will be done.
Posted: Tue Aug 11, 2015 9:14 am
by Dragos Filimon
I want to get the water intake for AC below the ice chest, between the centerboard and water tank. (the X in the drawing). I want to be sure there is nothing between the inside and outside walls (I do not want to go through the water ballast). Has anyone done this before?
Posted: Tue Aug 11, 2015 2:03 pm
by Gazmn
Dragos Filimon wrote:I want to get the water intake for AC below the ice chest, between the centerboard and water tank. (the X in the drawing). I want to be sure there is nothing between the inside and outside walls (I do not want to go through the water ballast). Has anyone done this before?
Wait A minute!!
Put down the drill, hammer, saw or other implement of destruction. The AC installs that were commented on were $100 window units that we redirected
& made nautical "accommodations for". Namely bottom half of companionway hatch. - No holes in the boat - ESPECIALLY Below The Waterline
Marine AC installs have been done - but non of those owners have chimed in - yet.
Seriously, think twice - & then a third time if you still want to put a hole below the waterline in this kind of boat
Posted: Wed Aug 12, 2015 7:53 am
by Dragos Filimon
I know. It is scary. But it was done before. And the unit that I chose, Marineair Micra is small enough to be run on batteries for several hours. Believe me I won't cut until 100 % sure of result.
Posted: Wed Aug 12, 2015 9:04 am
by Obelix
Posted: Wed Aug 12, 2015 9:17 am
by tp56ihs
Also, The water ballast covers the whole bottom
of the boat inside the (2) risers shown in your drawing. I think
Posted: Wed Aug 12, 2015 9:24 am
by Dragos Filimon
The AC page is here
http://www.marinaire.com/Marine-air-con ... aQod4VAPtg
Is 500 W and the pump will be another 100 W. But keep in mind that I have about 300 Ah installed, which is unusual for an x.
Now talking about the water ballast, that is what I am afraid of- tiny space between inside and outside that will interfere with good insulation. That is why I want to know if anybody did it before.
Posted: Wed Aug 12, 2015 9:34 am
Dragos Filimon wrote:The AC page is here
That setup will give you about 3 hours of AC with standard 300 Amp hour batteries. Does that fit your cruising needs? Seems pretty light to me.
Posted: Wed Aug 12, 2015 9:39 am
by Dragos Filimon
It is better than nothing.
Of course when in marina I will use shore power.
Posted: Wed Aug 12, 2015 10:03 am
by vkmaynard
Another convenience with a window unit is you can run it while on the trailer doing work or acting as an RV.
Victor
Posted: Wed Aug 12, 2015 12:00 pm
by wbpenney
I think that you may find that 6000 BTUs is a little light for a water cooled unit. I had a 5000 BTU window unit and it cooled the center area ok. Went a 9000 BTU mermaid water cooled unit and it was not enough. Swapped it out for a 12000 BTU unit and I can cool from bow to stern. I have my water inlet under the port stern sleeping area outside the ballast stringer. Have pics of the install on boomboom2.blogspot.com
Hope this helps
Bill
