Winslow (Woodruff) Key Lost!!!!
Posted: Sat Nov 14, 2015 4:27 pm
by Gazmn
I'm having an "Oh $H!t" moment.
I lost that half nickel sized widget that locks in the steering wheel :x
Who, how & where can I get another one... :?:
Anyone :cry: :?:
Re: Winslow Key Lost!!!!
Posted: Sat Nov 14, 2015 4:44 pm
by Ixneigh
Make one? Ss washers cut In half in a pinch?
Ix
Posted: Sat Nov 14, 2015 5:01 pm
You talking about this thing?
Posted: Sat Nov 14, 2015 5:10 pm
by Gazmn
RussMT wrote:You talking about this thing?
Yep :)
Posted: Sat Nov 14, 2015 5:18 pm
by Spector
Woodruff key..any bolt supply house should handle them
Re: Woodruff Key Lost!!!!
Posted: Sat Nov 14, 2015 5:36 pm
by Gazmn
WOODRUFF KEY!!
No Wonder I couldn't find it Thank You!
Posted: Sat Nov 14, 2015 5:47 pm
by Gazmn
Any clue what size we use???
Posted: Sat Nov 14, 2015 5:58 pm
by kmclemore
Most Home Depot / Lowes / Sears Hardware will have hardware bits bins and they often have Woodruff keys. You need one that fits in the slot you have, so measure the width of the slot and that will tell you what size you need.
Posted: Sat Nov 14, 2015 8:45 pm
by seahouse
Hey Gazmn!
Note that in an emergency you might be able to reassemble the steering wheel without this key and still have functional steering.
I have never had this apart on these boats, but that is assuming the wheel is also on a locking taper that will snug up when a nut is turned. The Woodruff key / keyway/ keyseat is used to hold an index in one position and to absorb any torque that is beyond what the friction in the locking taper will absorb, so abrupt steering inputs will need to be avoided, although some turning/ slipping would not be catastrophic.
:wink:
Posted: Sat Nov 14, 2015 10:38 pm
by Gazmn
Thanks Guys :)
In a few hrs I went from uh oh!... To Oh... ok I can fix this - & get extras :)
As always, you guys are GREAT. I learned What the Hull the thing is called & Where I can get it. Who's better than u guys?
Nobody 8)
Posted: Sun Nov 15, 2015 6:58 am
by Tomfoolery
For quick results, your best shot is a True Value or other franchise hardware store. I don't recall ever seeing key stock (straight) or Woodruff keys in a BORG, but every good hardware store stocks them in a variety of sizes.
Posted: Sun Nov 15, 2015 4:56 pm
by shrektruck
New to sailing and I saw the title and thought I'd better see what a ''Winslow key'' is. Ha ha, True Value or Napa is probably your best bet.
Re: Winslow (Woodruff) Key Lost!!!!
Posted: Sun Nov 15, 2015 5:03 pm
by kmclemore
 ! kmclemore:
Changed the title to make it a bit more searchable in the future.
Posted: Wed Nov 18, 2015 8:13 am
by Gazmn
Thanks Mod,
Kev you & The Boys do a great job. For Free :!:
Thank You :)
Posted: Wed Nov 18, 2015 10:49 am
by kmclemore
Gazmn wrote:Thanks Mod,
Thank You :)
Thanks! Nice to hear a little kudos once in a while.
