Page 1 of 3
Table/Bench Seat Mod
Posted: Tue Aug 23, 2016 12:28 pm
by Geraghtyr
My 1st Mod, other than replacing the bulbs with LCD bulbs...
Idea:
When not needed, remove the factory table and add more seating for lounging and relaxing.
Mod:
Added a bench seat and cocktail table than can be raised and lowered.
Here's a photo of the unfinished 1st fit.
Rob
Re: Table/Bench Seat Mod
Posted: Tue Aug 23, 2016 12:56 pm
by paul I
Very nice. That certainly does open it up quite a bit doesn't it.
Posted: Tue Aug 23, 2016 1:02 pm
by bobbob
Wow! That is a fantastic idea! I may steal that design from you completely
Posted: Wed Aug 24, 2016 6:59 am
by Spector
Pretty slick idea!
Posted: Wed Aug 24, 2016 7:06 am
by Tomfoolery
Looks good. The original table is a lot bigger than it needs to be, IMO, at least when it's not being used as a berth.
And remember that it doesn't have to be round, if you want to make more walking space on the port side.
This one even has a storage bin in it, with a removable hatch board in the top with a finger hole. Might give you (or someone else) some additional ideas.
Posted: Wed Aug 24, 2016 7:29 am
by Obelix
Tomfoolery, that would be an outstanding mod for the Mac!
Just need to apply the beam-stretcher to the hull.
Obelix
Posted: Wed Aug 24, 2016 7:49 am
by Tomfoolery
Posted: Wed Aug 24, 2016 8:03 am
by Geraghtyr
I like the idea of asymmetrical table. Could possible do fold up hinged table?
I went round for two reasons.
1. people sitting on the port side bench seat can set a drink on the table
2.Lowe's had it in stock
Posted: Wed Aug 24, 2016 11:41 am
by RGF
Excellent idea! I think I'll rip that off too!
Thanks!
Posted: Wed Aug 24, 2016 2:19 pm
by sailboatmike
Tomfoolery wrote:Looks good. The original table is a lot bigger than it needs to be, IMO, at least when it's not being used as a berth.
Im loving this, maybe just slit the hull down the middle and add another 18 inches and it may start to be feasible, I would think an 18 inch wider Mac would be a pretty awesome sea boat, of course trailering becomes an issue
Posted: Sun Feb 12, 2017 9:59 am
by Photoman369
In looking at this I got the bug for more room. Here's what I am planning. Using existing equipment with almost no purchases. Take the existing table top and cut it in half on a line bow to stern. Put hinges on the underside counter sunk so the surfaces will be flush when the table is folded in two. This will then be used as a bench in the groves already there for when you use the table as a berth. It's already the perfect size. Just remove the leg from underneath and take the table off the wall fold it and its a bench. Unfold it and put the leg back on and flatten it out. The hinge will keep the table flat and solid for use as a table again.
Seems it will work any thoughts?
Posted: Sun Feb 12, 2017 12:00 pm
by RGF
Don't forget,Photoman, you will also have to notch the turned down edges so they won't hit when in the dropped position and worse, I think the table will be too wide to fit between the vertical fronts of the bow and stern benches. There's always a solution to every problem though....
Posted: Sun Feb 12, 2017 12:09 pm
by RGF
After more thought, maybe you could hinge the table so that the hull side folds up against the hull and the support leg side sits down in the "berth" grooves....but maybe that's what you were saying all along. Sorry, silly me, shutting up now...
Posted: Mon Feb 13, 2017 9:16 am
by Photoman369
RGF wrote:After more thought, maybe you could hinge the table so that the hull side folds up against the hull and the support leg side sits down in the "berth" grooves....but maybe that's what you were saying all along. Sorry, silly me, shutting up now...
Pretty close to what I was thinking. I planned on folding the table in half right back on it self and resting it in the berth grooves, not having half be a seat back. And yes counter sink both sides of the hinge. Thanks for the response
Posted: Wed Oct 27, 2021 6:37 am
by dlandersson
Very nice
