Road Warrior trailer has a case of "throat cancer"
Posted: Thu Sep 21, 2017 10:22 pm
For years I've read accounts of original steel Mac trailers suffering fractures at the base of the tongue, near where the angled sections of the trailer are welded to it. I've known that this is a result of water entering the open end and rusting the channel stock from the inside. I've kept a close eye on my trailer tongue, watching for signs of failure. My trailer is 15 years old, and has carried our boat on 4 cross country trips, plus many more shorter journeys, probably over 40,000 miles in all. It's been dipped in both fresh and salt water while launching our boat, countless times. I've always been very careful about rinsing it off thoroughly with fresh water right after salt water launches. Early on I added a tandem axle. I've replaced the bunks twice, and have repainted the trailer twice. Most recent paint job was 2 years ago, done professionally following a thorough sand blasting. I occasionally tap that part of the tongue with a hammer, listening for the sound of solid metal. It's always seemed sound, and I attributed its good condition and long life to careful maintenance and the fact that, when not being used, the trailer is stored here at home on the dry east side of the Cascade Mountains of Eastern Washington.
Yesterday while getting ready to put the boat's winter cover together I glanced at the tongue and noticed a little raised blister under my still shiny new paint job, at the base of the tongue. I also spotted a little bit of rust stain on the blister. I got my hammer out and gave it a tap and, to my surprise, I was able to knock a 1 inch diameter hole in the side of the tongue. I poked around inside the hole with an awl and found it filled with ugly flakes of loose, heavily corroded iron. An ugly sight, to be sure. Fortunately, I didn't make this discovery the hard way, while towing the boat down the highway out in the middle of nowhere. It still looks sound enough for a 6 mile tow down to a nearby welding and machine shop, where I plan to get it properly repaired. I'm not yet ready to retire my trusty Road Warrior trailer, and once the tongue is properly repaired, I look forward to putting many more miles on it.
