Water ballast - Close it permanently?
Posted: Sun Apr 01, 2018 2:23 pm
Hello,
I am currently repairing/restoring a Mac 26S. While repairing I also took the opportunity to do some mods which have increased the weight. (I added a coolbox next to the sink, 2 batteries (25kg each), solar panel, 120 liters water tank, bow anchor, and a marine head unit).
This weekend while browsing the internet for some stuff for the Mac, I came across a post from an owner who loved the boat but reported that one day due to a malfunction of the water ballast tank while having 5 persons on board (significant amount of weight), the ballast tank started leaking water on board through the air vent to the point that the situation became dangerous. I believe this situation happened due to a malfunction of the bottom valve that, in combination with the weight of the 5 persons on board caused the boat draft . This caused the boat draft to be bigger than normal and therefore increase the pressure on the valves.
Here is a link about another similar situation, however in this case it was caused by misuse of the valves+heavy loading the boat.
http://analogengineering.com/sail/mac/wb.html
Given this situation and also taking into account that both air vent plug and both valves need to be replaced in my boat I was wondering if closing permanently the bottom valve would be a good idea. This way the ballast tank could still be filled/emptied with resource of a water pump. The boat will stay in a marina all year and only be pulled out of the water occasionaly for maintenance reasons.
What do you guys think? Is the idea of closing the bottom valve for good worth considering?
