One job led to another
When replacing wheel bearings today, I noticed this on a tire.
Now I need to replace a tire also. I am glad I caught this in time.
Re: One job led to another
Yikes! That could have made for a long day. As usual, the tires came apart before the tread was worn out...
Danhux
Post by Danhux »
If you are doing all that, might as well replace the studs and lug nuts. I started doing the same thing, in the end I replaced the U bolts, bearings, raises, seals and tires (wheels included). To save time I cut the U bolts off with a saws all. I couldn’t find anyone that would turn the rotors to resurface them.
paula_ke
Post by paula_ke »
Just curious, what were the date codes on those tires!
Captain Paula of the good ship AirWave
:macm:
paula_ke wrote:Just curious, what were the date codes on those tires!
:macm:
Good question.
My intentions are to check for date codes on both tires and the spare tomorrow.
After discovering the tire problem, I stopped for the evening.
:macm:
Good question.
I was thinking the same thing. If one is bad from age, the other(s) is(are) likely not far behind. Mine came with the original tires from 1999 ( :o ) and the added second axle was only a couple of years fresher. Those two are spares now, but it got four new tires and galvanized wheels the second year I had it. Plus new disc brakes (rear axle only) and coupler and lines, lighting, bunks, and so on. But I digress. :|
I checked two of the three tires (single axle with one spare).
The spare is dated August 2016.
The bad tire is dated July 2012. Way overdue.
I have not looked at the other tire yet.
Baha
Post by Baha »
Good job! I ignored my tires, bearings and brakes (surge brakes here) for 2 years. Ended up replacing all the cables, shoes, bearings, and tires....lesson learned!
I don,t do a lot of trailing like some guys on this site do as I mostly slipped my boat for the first 4 yrs , my trailer is 2008 in 2014 I removed my tires & flipped them on the rims as they were wearing on one side due to my boat being loaded heavy most of the time & I got another 2 yrs out of them but as I say I don,t trler much so my trailer is pretty much in new shape
before my trip to haul the boat over the Rockies to Vancouver Island BC I re-adjusted the bearings after inspecting them & replaced the wheel seals , rebuilt the brake caliper,s due to the fact one of the piston boots was cracked there fore exposing the brake pistons to water & poss. corrosion , the brake pads still had 60% wear in them to go but due to their age 8yrs old I was not taking any chances of them becoming dislodged from the brake shoe pads due to poss corrosion between the pad & shoe weather they r glued on or riveted to the pad shoe ! I would never have forgiven myself if I ran out of brakes coming down the Rocky Mountains ! so the brake pads were replaced with the highest heat/load application i could find , I also replaced all my truck rotors, caliper,s brake pads & parking brake shoes & all caliper brake flex lines as they were due anyway
I replaced my old bias ply tires with 2 new radial tires an a extra radial tire & rim giving me 2 spare tires :wink:
Anyways I was loaded to the gunnels coming down these Rocky Mountains going thro AB & BC & I can tell ya even with a 9600# tow package & trk some times auto trans manually put into 2nd gear to keep that load from taking control of my descent I could sure smell them brakes getting hot & sayin to myself Geez was that ever a smart move ! :)
And if u do a lot of trailering then Radial tires r the only way to go !, I went with commercial trailer tires way above my rating as I knew there would b times I would b doing 130km/h so I did not want any :o
Bottom line this is not maintenance schedule that should cheap on if u do a lot of trailering or plan a big trip !
Oh Well my Rant is over now lol
Not a rant at all John.
