Mac19 restoration
Posted: Sat May 18, 2019 2:31 pm
Hi
I have recently acquired a Mac19, complete, but in a very bad shape. Lots of scratches and weed grown on it, otherwise no holes or substantial damage to the fiberglass. Mast complete but sails in very bad shape, couldn't tell if they're damaged or just dirty (haven't unrolled them). Metallic lines were cut and I believe I'll need a crimping tool.
Found about 100 liters of water inside it. Not in the ballast tank but inside the boat, in two compartments. Got it out but it stayed there for over a year (boat was in a hangar). I believe this water got in through rain because boat was on water for a long time and also since last year, in the hangar, it didn't leak.
So, here are my questions:
1) I'm planning to use an electric water pump and hoses to pump water out it after i was it on the interior with water and 5% cholorine. Is this a bad idea?
2) Sails, the old ones, if they have holes, can they be patched? Or where can I get new ones?
3) The centerboard, how do you raise and lower it from inside?
4) What products should I use to wash and clean it both inside and outside? Should I use car wax? For some reason it gets dirty very fast, like it's attracting dust.
5) When using it as powerboat with Tohatsu 40HP 2 stoke engine, ballast tank should be empty, full or half-full?
6) It doesn't have the US Coast Guard Tag, and it does not matter since it's in Europe. But I will have to declare to local naval authority max number of persons to be on board. Can I go with 6?
7) I don't know what make and dimensions for the original tires. Any help?
TY
TY
