Rub rail replacement for 1985 Mac 25
Posted: Sun Jun 28, 2020 9:22 am
I want to replace the damaged original rub rail on my 1985 Mac 25. That rail has an aluminum extrusion with a central insert. The extrusion is secured by about "a million" small nuts and bolts.
Has anyone done a replacement on a Mac 25. If so, what brand of rub rail did you use and did you remove the extrusion and replace it with a vinyl/rubber rub rail with an insert?
Thanks.
Thanks.
