Macgregor 26s keel
Posted: Sun Sep 19, 2021 4:29 pm
Had a look at a 26 swing keel, and in the area close to the pivot point, there are two plugs, one was actually missing. The owner, seemed to indicate they’re access to the bolt through the keel, but I couldn’t be sure.. Unfortunately one of the plugs were missing, and so it seemed you had a direct entry into the cavity there for water (however I can’t tell if it was a large area).. This approximately 1.5” hole didn’t seem to provide water into the boat, but still wondering what it was, anything that should be plugged, or if water entering this area was a concern..
