Troubleshooting 1989 Yamaha 9.9HP Outboard
Posted: Fri Aug 05, 2022 3:49 pm
I need advice troubleshooting my 1989 Yamaha 9.9HP FT9.9ELF outboard. It won't start. I use it on my Macgregor 26D sailboat so it's not used a lot. It was working fine last year, then I stored it at home in my basement as usual (so no freezing, no winterizing). I put it back on the boat today, changed gear oil and engine oil (and new oil filter), put fresh gas in, and it won't start. Starter works fine, it turns over, but not even a "cough" or smoke, it's not even trying to start. I checked fuel flow and when I squeeze the bulb it squirts through the tubes running through filter and pump, so it's feeding it up to the carburetor. I unscrewed both spark plugs and checked for spark - there are sparks (tiny ones but visible in daylight, I'm not sure how are they supposed to look). Tried another pair of plugs too - no effect. I think the sparks have signs of wetness inside - maybe gas in cylinders? Could it be flooded? There's no movement in the top transparent bulb over the carburetor - is there supposed to be fuel visible on top there? Anyway, what could have happened over 10 months it was stored at home? I'm not sure if I could just drain the carburetor - there is a screw at the bottom, but not sure what it does... Don't want to mess it up worse than it is. It was running fine for 5 years since I got it. I rarely use the boat so it only runs several hours per season. The only thing is after it runs for a while and then sits for a couple of hours, it was difficult to start, but it would always start after a few tries. I did clean the carburetor 2 years ago, replaced the impeller when I got it (5 years ago) and it was fully serviced about 6 years ago by previous owner - everything was shiny new including all the rubber parts when I got it. Still looks good. For now I left plugs unscrewed so if there's gas in cilynders it can evaporate. What would be my next steps?
