26X/26D jib sizes
Posted: Sun Sep 25, 2022 2:49 pm
I've tried searching here and elsewhere but I can't find the info and give up... will the hank on jib from a 26X for on a 26D or vice versa?
Discussions relating to the MacGregor line of trailerable sailboats
https://www.macgregorsailors.com/forum/
https://www.macgregorsailors.com/forum/viewtopic.php?t=29277
Thank you. Hoping to find the same info for the 26X.Stickinthemud57 wrote: ↑Sun Sep 25, 2022 5:56 pm If you are looking for jib dimensions, I might be able to help a bit.
I have a 26S, which is basically the same as the D when it comes to sails.
The basic replacement 100% hank-on jib for this boat, as supplied by Blue Water Yachts, is a Rolly Tasker sail with the following dimensions:
Luff 23.375', Leach 21.25', Foot 10'
Not sure if it differs for the X
Not sure how I missed that, but thank you. It looks like the jibs will fit interchangeably. I just scored what appears to be a new old stock Doyle jib labeled 26X for $225 shipped. I'll add it to the sail inventory for my 26D. Assuming this jib is a 100%, I now have an 87%, 100%, 109%, 150%, and an assymetric spinnaker.
