Harnessing and Jacklines
Posted: Thu Jun 08, 2023 1:12 pm
by EvenKeel16
HI Guys,
I'm looking for input on Harnessing and Jacklines. I'm starting to go out more and more by myself. I guess I'm a little more safety minded than most - Ive been the man overboard before.
So how many of you guys are harnessing? How are you tethering in? My boat is a 26S - can anyone send pictures of where you are running jacklines?
thanks
EvenKeel
Re: Harnessing and Jacklines
Posted: Thu Jun 08, 2023 4:45 pm
by Stickinthemud57
This topic is of interest to me. I single-hand a lot and frankly am somewhat lackadaisical about such things. Perhaps because I don't go out when conditions are too frisky, and I sail on a lake that is fairly small. Still, the ramifications of going overboard should not be ignored. Looking forward to seeing others comment.
Posted: Thu Jun 08, 2023 8:35 pm
by kingtoros
The last time I was out on blue water was in a 300' steel tube with a bunch of other squids. So.. I won't give advice there.
Life jacket is I think your best friend when it comes to brown water. Harness has me thinking snagging and dragging...
I also don't single hand, at least the Admiral or one crewman.
Posted: Fri Jun 09, 2023 1:18 am
by kurz
Sorry, wir but life jacket does not help when are alone. You sit in the water, boat rides away, you die slowly...
I checked out to clip the harness in both sides of the lifelines. So you stay in the middle of the boat. Just 1 idea, so no additional lines are needed...
Posted: Fri Jun 09, 2023 4:01 am
by kingtoros
kurz wrote: Fri Jun 09, 2023 1:18 am Sorry, wir but life jacket does not help when are alone. You sit in the water, boat rides away, you die slowly...
Yeah, in blue water. I should have qualified brown water as lakes/rivers. If the boat sails away in brown water it hits the shore or somebody's dock.
Out in the ocean, doesn't it make sense to fasten satellite/radio sos gear/beacon? I take a worst case approach. Unconscious MOB.
Posted: Fri Jun 09, 2023 5:56 am
by pitchpolehobie
Run lines to cockpit.
Dont get on deck by yourself.
Always 3 points of contact
Always think if I am doing something dumb or risky change it.
If you get on deck power down and lower sails first.
Attach a proximity kill switch to turn engine off if u fall in
Tow a long floating line that can be pulled and disengages the mainsheet so sail luffs and boat stops.
:macx:
Posted: Tue Jun 13, 2023 6:18 pm
by JeffJuneau
Speaking of harnessing points, is the stainless grab bar on top of a 26M helm an acceptable point to attach a harness while in the cockpit?
Posted: Tue Jun 13, 2023 6:25 pm
JeffJuneau wrote: Tue Jun 13, 2023 6:18 pm Speaking of harnessing points, is the stainless grab bar on top of a 26M helm an acceptable point to attach a harness while in the cockpit?
I would think so. It's pretty beefy. Mine has 4 bolts to the pedestal.
I really like the ideas in this thread. Line to the main sheet seems brilliant.
I can't imagine trying to board the boat while moving. But if you could stop her, that might be the edge up.
Posted: Tue Jun 13, 2023 7:24 pm
by JeffJuneau
Thanks Russ, I will try connecting to the grab bar next time I attempt a solo sail. Agree that this is a useful thread for me also. Jeff
