Replace steering for rudders with a tiller?
Posted: Sat Jan 13, 2024 11:07 pm
I'm very soon going to be replacing my 29 year old Honda BF50 with a new Yamaha 85 2-stroke. Almost the same weight, about 5kg heavier, but more power and being new, easier spare parts and servicing.
Engine has already been ordered, waiting for it to arrive and the local boat guy to help fit it. The Honda will be placed on my new (2nd hand) river boat, which is a 22ft locally-made thingy.
A big problem with my elderly 26X (1995) is the steering is a sloppy mess, making it impossible to just maintain a straight line without constantly yawing the steering from one side to the other. I presume later models had a better design, as there are so many links and wobby bits with mine that it's hard to imagine anything worse really.
Yes, I could replace the main steering box and cable, but I suspect it wouldn't help much.
So I'm considering the idea of crafting a conventional wooden tiller, basically a long stick, to turn the rudders as steering when under sail, and just bypass all that gumpth and connect the new engine to the steering like a normal boat?
Perhaps put some kind of folding latch, so it can be moved out of the way when motoring and using the steering wheel, then when sailing, raise the engine and unfold the tiller handle? Or screw it back in or something? Obviously I don't want a long sticky thing in the cockpit if it's not being used.
What do you guys think of that idea?
Or is there some kind of modern kit that will give me proper, smooth steering that works?
You may recall this old vid:
That's just hopeless really. That much slop, without turning the engine or the rudder
