Hi Warfin
Original boat construction was done with polyester resin…. That was back in 1999
That a few years back in history and if there were any POs then there may have been prior repairs accomplished that may or may not have been with polyester &/or epoxy resin. There is no simple non destructive test one can do to determine one over the other type of resin.
So one generally applies a logic tree
- Determine the original construct material
—> polyester resin
- Take a look at the at the area in question to see if there is a prior repair
—> No — then good chance that it’s still a polyester surface and one could repair with polyester resin
—> Yes — then it’s a bit more complicated as it’s now a bit of a dice toss as to whether it is a polyester or epoxy resin surface
=== one can only apply polyester resin over polyester resin ( Why? ———- polyester resin applied over epoxy will fail to bond properly)
=== one can apply epoxy resin over either polyester OR epoxy resin surfaces
So if you don’t know for certain and you might just want to go ahead and use epoxy resin for your repair or modification.
Given the limited area the cost differential between polyester and epoxy is minimal.
When you go to do your repair I assume that you will grind or sand back to good material to bond to.
I’d highly suggest that you start with a biaxial cloth layer or two for strength of structure.
If you have to reconstruct a lot of thickness for the leading edge geometry one can then use chopped fiber (sometimes called ‘hair’) with resin like a putty to do shaping. (This is something one can buy or make from scrap biaxial cloth). This can be a bit messy but if done carefully it makes a very strong intermediate substructure.
Once you’ve allowed the resin to fully cure one would then sand it to the desired shape and a little bit less than final shape.
Then on the cleaned scuffed surface one can apply a final layer, overlapping the repair by about an inch or more, of biaxial cloth fully pressed to surface as smoothly as possible.
Allow to get tacky then apply fresh resin to make a thicker resin only topcoat to provide material for final sanding to shape and minimize any sanding into the cloth layer.
After the resin has fully cure (and a bit more time if possible) paint with an epoxy barrier paint. Two coats or more is recommended to avoid any osmotic issues.
Disclosure: Our own keel needs some TLC. At sometime prior to our adopting Over Easy one of the POs made a resin only repair to the keel leading edge…no real prep and no glass fiber…
It’s brittle and has been degrading over time. While there is no safety or structurally at risk.. it just looks like Fido’s chew toy at that location. We’re gonna take care of it before the start of next season. A good winter in the garage project.
Good Luck and post pictures if you can!
Best Regards
Over Easy
