Leaking Ballast Tank Idiocy - 26X
Posted: Thu Jul 11, 2024 12:37 pm
Hey! You know that water that pools in the aft area under the cushions? Condensation, leaks, etc. I hate that. Always mopping stuff up. So I got "clever" a while back and drilled a couple 3/8" drain holes.
"Apparently" one of those, on the stbd side, was right over the ballast tank .. the fibreglass I was drilling through sitting right atop the ballast tank, so when I went through, well, you know it. Dum te dummb dumb.
I discovered the results of this after a frenzied week prepping the boat for a friend's wedding, 23 NM away. No highways or airplanes go there directly, so boat was the only option. Chucked the mast, finished electrics, and prepped. At dock, 23 miles from home, I noticed I was listing to stbd. Quick inspection revealed much water. Pump! Good thing I also had my 12-volt diaphragm pump and lots of tubing, to direct water into the head sink drain.
I was there for 2 days, and rigged a system so I could pilot and manage the pumps. It was better after leaving dock, I drained the ballast. (still not being aware of the leak source at that time, thinking it was maybe holes I drilled in the galley floor to allow me to stiffen the crunchy soft feeling. Had I drilled through? I didn't think so ...)
Once home, and mostly drained, Wifey mad, both of us curious, I was preparing to rip up the galley floor when I noticed a remnant of 5/8" tubing I'd used for the fuel vents. It fit PERFECTLY into the ballast tank vent hole. I blew in and heard a WHOOSH behind me. With Wifey's help I tracked the whoosh to. ... the hole I drilled for, ironically, a drain in the aft berth.
Using G-flex epoxy, wetted and then thickened, and a zip tie and a silicone cup, I filled that damn hole. As of yesterday the tank holds air pressure (breathing like inflating a balloon) and also vacuum ... for quite a while. No more whoosh! (I also replaced the transom valve seals, which I suspected were letting water in despite being closed).
What a dumbass I was
. Don't let this happen to you!
I'm of half a mind to install a pump to allow ballast emptying when at dock, if so desired. I dunno ... hopefully will never be necessary again.
