Companion way hatch dimensions
trswem
Sailboat: MacGregor 26D
Post by trswem »
Hello all. Does anyone have a resource for the exact dimensions of the companion way hatch? I want to may an insert that I can put in when we sleep with a flush mount 12v fan to move air through the cabin. We've had some clammy nights lately! I'd go measure mine but my boat is moored 1.5hrs away.
Thanks!
Maraquita
Re: Companion way hatch dimensions
Post by Maraquita »
Assuming you are talking about your "D", and assuming that neither of our boats is modified to badly, the top is 32 inches wide, the bottom is 22 1/4 inches wide and it is 17 1/2 inches high. That is the dimensions of the original fiberglass hatch board. The hole, of course is slightly smaller, by about 1 1/2 inches on both sides and the bottom to allow for overlap while sitting in the holders.
trswem
Post by trswem »
Maraquita wrote: Fri Aug 30, 2024 4:13 pm Assuming you are talking about your "D", and assuming that neither of our boats is modified to badly, the top is 32 inches wide, the bottom is 22 1/4 inches wide and it is 17 1/2 inches high. That is the dimensions of the original fiberglass hatch board. The hole, of course is slightly smaller, by about 1 1/2 inches on both sides and the bottom to allow for overlap while sitting in the holders.
Perfect, thanks Maraquita!
