Shelf Mounting - 26M
Posted: Wed May 07, 2025 10:04 am
Hi guys,
I have a teak shelf that was mounted by screwing it directly into the liner on the port side near the companionway. The road vibration has caused it to fall off a couple times. I tried double sided tape and larger screws, Nope. I tried epoxying stainless threaded washers. Nope they popped off. I saw on a post at some point in time that someone used a track mount. Really cool. What have you guys used? Sometimes you need to reach out to the think tank.
Note: The space between the liner and the hull is really tight. Rivnuts will not work. In fact the PO drove the screws so the heads just protruded the hull. I found out by tearing up my buffer pads. He used drywall screws!!
KB
KB
