Bulb for Mast Light?
Posted: Thu May 26, 2005 8:16 am
by Handymom
I am trying to locate information on what type of bulb is need for the mast light.
Posted: Sun May 29, 2005 4:59 pm
by Brian26x
My masthead light was out. I had the same question as you. I checked the bulb from the connection on the deck, using a multimeter. Bulb was good. Cleaned connection on deck, and the light now works fine.
Posted: Mon Jun 06, 2005 5:43 pm
by Handymom
I have a 1999 26x. I dropped the Aqua Signal light bulb in the water when I was trying to figure out what was wrong with the light. Do you know where I can get the aquasignal bulb?
Do you also know where I can find a owners manual online. Since we miss placed ours over the winter.
Thanks
Posted: Mon Jun 06, 2005 5:52 pm
by Tom Root
Aqua signal bulbs are actually German manufactured, same as Beemers, Mercedes, and V.W.'s I am fairly sure you can match part number at any auto parts store, or go to the V. W. stealership. Correct me if wrong, but that is what I recall using on other Aqua Signal lights!
Here's the PDF version that Heath was so kind to host!
http://macgregorsailors.com/manuals/index.php
