Adding wheels/tires to lift bow
Posted: Mon May 30, 2005 8:34 am
by SURV69
I'm considering adding a couple of tires on a bracket to reduce the pressure off of the bunk-boards and to make it easier to lock up tight to the bow-chock . . . maybe with a cam, so I can lower it an inch or so after tieing off.
Has anyone ever done something like this?
The MacGregor Bump
Posted: Tue May 31, 2005 10:22 pm
by Robert
SURV69,
The bow not quite making it to the stop is a trailer geometery issue. I once put a roller just aft of the foward most bow bunk and that made it a little easier to pull with the winch that last couple inches or use the MacGregor Bump. However, the first time I had a rough windy not graceful return to the trailer, the bracket for the roller was smashed. For me, the easiest way was just to to the MacGregor Bump - - just after pulling up the ramp, apply a little bit of brakes and the Mac26X will slide right up to the stop. I had the bow bunk carpet wear through and replaced it using monel staples for corosion resistance.
I think you will find as I did with the roller, that adding "a couple of tires" will not make the bow automaticaly sit in the bow stop. I think the trailer needs to be modified with a tilt or something for the boat to just float to the stop.
It is important to have the bow all the way up to the stop for enough tongue weight to keep the trailer well under control at highway speed.
