Pls Help: Can I tow 3000lb (boat+trailer) with Montero Sport
Posted: Sat Jun 04, 2005 8:23 am
Dear All,
I have a Mac24 with outboard and trailer I guess the overall weight is around 3000lb. I have a single axle trailer with no brakes at all.
Towing car = 2000 Mits. Montero Sport with 5000 lbs tow capacity. 3.5lt with 200Hp (4sp) auto transmission.
My questions, since the car is mid-size SUV with unusally larger towing capacity it does not have transmission cooler, and I wonder if anyone towed mac with this SUV.
Should I install transmission cooling system, if so will appreciate any suggestions and web-links.
Regarding the single axle trailer, I realized that once I put the outboard I got negative pay load so trailer front going up, after rearrenging the load I guess now trailer front does not go up but I got some pay load may be around 100-150 lb. Does anyone has any idea is it an acceptable load distribution on single axle trailer.
Last question is do I surely need break system on the trailer, or I can survive without it.
Thank you so much for all interested parties, and looking forward to hearing from you guys.
All the best for all sailors.
Erol
Erol
