Towing Points on an M
Posted: Sat Dec 17, 2005 12:14 am
by Hurley
I intend to tow a water toy for the kids this year. Where should I attach tow lines on the boat?
Thanks in anticipation
Posted: Sat Dec 17, 2005 12:29 am
by Balu
I pull my kids on a tube with the line connected to the rear mooring cleats via a line and pulley available from shops who sell ski's etc. Whether this is the right place or not I have not had problems as the height of the stern keeps the line clear of the motor.The cleat fixings are strong enough.
I leave the pulley on the outside of the push-pit so that it moves freely from side to side.
Posted: Sat Dec 17, 2005 8:06 am
by baldbaby2000
We also use the stern cleats. I haven't found a better place. I worry a little about the line getting wrapped on the rudder in the up position so I keep a close eye on it.
BB
Posted: Sat Dec 17, 2005 9:47 am
by Balu
I drop the rudders so the line just clears them,but makes it difficult to board the boat.
by Balu
Posted: Sat Dec 17, 2005 11:46 am
by kmclemore
I use the rear cleats, though you're right that the rudders tend to get in the way. Presently I just tie to one cleat and I've had no problems, but I've considered making up a Y-yoke, where I'd have a loose loop running from cleat to cleat, then have a pully running in that loop and tie a line to that, leading to the pull-toy.
Posted: Sat Dec 17, 2005 6:34 pm
by Dimitri-2000X-Tampa
That's how I do it on my X. I make a bridle with about a 10-15 foot long piece of line tied between the two stern cleats. I tie a small (floating) fender into the middle of the bridle so that it won't sink down to get in the prop. Then I attach the tow rope near the fender also. The fender comes out of the water at speed.
Posted: Mon Dec 19, 2005 7:44 am
by DLT
I had the motor shop install some ski-eye's just above the waterline on either side of the motor.
They backed it with some marine plywood to spread the load. They work fine so far...
Posted: Mon Dec 19, 2005 10:56 am
by kmclemore
Dimitri-2000X-Tampa wrote:I tie a small (floating) fender into the middle of the bridle so that it won't sink down to get in the prop. Then I attach the tow rope near the fender also. The fender comes out of the water at speed.
Oooohh.. good idea! Thanks!
Posted: Mon Dec 19, 2005 11:42 am
by DLT
All my tow ropes and bridles are made of that polypropylene (sp?). The whole rope floats...
With my setup, I use those purpose built bridles, made for ski boats. They usually have some additional flaotation built in...
I have one bridle that the tow rope connects to a pulley that rides the bridle. This was a bad choice, as it is constantly changing the load from the tube... I can't keep the boat straight with it...
Posted: Mon Dec 19, 2005 12:30 pm
by Captain Steve
I too, like Moe, put one on the end of the anchor rode. I made a towing bridle for my dingy that terminates in a small float with a SS ring on it...easy to retrieve and snap on a shackle to get towing. Usually a couple of bucks at WM, but go to afishing store. like 2 or 3 for a buck!
Posted: Mon Dec 19, 2005 12:33 pm
by DLT
Anyone ever use any kind of rigid towing bridle?
I'd like to pull my canoe behind my Mac, but I don't want it running into the rear...
Posted: Mon Dec 19, 2005 1:06 pm
DLT wrote:Anyone ever use any kind of rigid towing bridle?
DLT, that sounds a little like the Dinghy Tow. (
Previous thread)
