Wow, what a mod!
Posted: Sun Mar 26, 2006 7:00 pm
by Helaku
I have been lurking on this site for a couple years. I have looked at most of the mods but this one really made me think wow!!
Very well done Zip Zimmer
Posted: Sun Mar 26, 2006 7:10 pm
by Beam's Reach
I've got to make sure the Admiral doesn't see this one. We've been talking about a galley mod, but there's no way mine is going to look that good! Beautiful!
I agree
Posted: Sun Mar 26, 2006 7:11 pm
by Divecoz
Nice Job Zip . . .now who is Zip ???
Posted: Sun Mar 26, 2006 7:53 pm
by Sloop John B
Get out of here, Zip. Mate sees this she'll want to overhaul the kitchen, dinning room and den.
My guess is you're on base with a good wood working shop and a lot of talent.
Posted: Mon Mar 27, 2006 4:12 am
That electrical box is too close to the galley sink - moisture will cause failure inevitably it should be moved immediately. (Bad cse of Galley-envy)
Seriously, that is one beautiful galley and makes my work with ClosetMaid look child-like.....I m working on a new plan for my lower galley area on my
this month - but Im running out of time...
Posted: Mon Mar 27, 2006 6:18 am
by LOUIS B HOLUB
Real nice job...
Posted: Mon Mar 27, 2006 1:39 pm
by Scott
And I thought this was fancy!!
Not!!
Posted: Mon Mar 27, 2006 5:56 pm
by Dimitri-2000X-Tampa
Galley's aside...Scott, I like that "sock on flip-flop" look though!
Thanks for your comments
Posted: Fri Mar 31, 2006 7:27 am
by Zip Zimmer
Most of my mods came from studying thr entries made on this site. I don't have a real sophisticated workshop but I have the basics, and a few toys like a Roto-Zip and a biscuit joiner than makes butt joints pretty easy to make. Any way on future mods I'll try to be more explicit about methods used, etc.
Re: Thanks for your comments
Posted: Fri Mar 31, 2006 7:54 am
by Bill at BOATS 4 SAIL
Zip Zimmer wrote:butt joints
Can you be more specific?
On second thought, maybe not.
Posted: Sat Apr 01, 2006 8:45 am
by Dubraque
Wife says,"Thank you! Thank you, thank you!" I think that means "I want one too!" Thanks a lot, Zip!
Seriously, that is some awesome cabinate work.
Question about those 3 doors
Posted: Sat Apr 01, 2006 9:59 am
by Divecoz
Do your 3 cabinet Doors swing out or pull down ?
What a mod
Posted: Mon Apr 03, 2006 9:13 am
by Zip Zimmer
The cabinet doors have no hardware. I used velcroe on the top/bottom which works pretty well even in a fairly steep heel. I did it this way so that I can remove any one or all of the doors. This means much greater access to work underneath the sink etc. On the inside of the doors, I glued some wicker placemat material to the wood side of the panel inset. So when I take them out, they can be used as serving trays. On the third I made a little magazine rack (again on the inside) to store charts, menus, etc. Also, if you look closely, you can see that I have some "paddles" mounted. These conceal some LED "step lights" which I bought at West Marine. They light up the countertop without being too bright.
Posted: Mon Apr 03, 2006 9:27 am
by Sea Pony
Holy smokes that is some nice work.
Does it weigh more than what was there before? I would think so much cabinetry might affect P/S balance. what say you?
What a mod
Posted: Mon Apr 03, 2006 9:35 am
by Zip Zimmer
Not too much weight was added. Remember I removed the old black plexiglass, the sink, tile and some countertop. I used 3/8" plywood, and laminate flooring for countertop. I was careful to use wood as thin as possible in building the shelves. Also to offset add'l weight, I placed my waterbag for my water system on the starboard side. I can add enough water to counterbalance the weight. When I get time, I'll submit that mod, too.
