Wear on Rudder Line "holes"
Posted: Fri Apr 16, 2004 12:08 pm
Hi guys,
I have been a lurker on these boards for a while but have never posted yet - but learnt much ! But now I have a question and need some help.
I have just been inspecting my whole outfit (Mac 26x - 1998 model) for wear ready for the new season and have noticed significant wear on the rudders where the line goes through the pre-drilled hole to lift-up/hold down the rudders. The original circular hole is being elongated where the line pulls on it. There appears to be no re-inforcing.
My first thoughts were to try and fill this in with GRP filler but then I realised the Rudders themselves are "hollow" and any attempt to do this is liable to block the flow in and out.
The rest of the rudders are in good nick and at the moment it is at the stage of needing a preventative repair - I want to stop this problem getting worse. At the moment they have worn through less than half an inch.
So has anyone encountered this ? How did you solve it ?
Thanks in advance
Mark
Thanks in advance
Mark
