Foestay Quick Release Lever
Posted: Tue Jul 11, 2006 3:28 pm
by jsserene
For those of you that have added one of these lever, how far up the mast did you raise the forestay tang and how long was the lever? The lever I have can adjust from 6 7/8" to 8 3/8" Any idea how high I should move the tang up? I already shortened the forestay by 4" to reduce the rake.
Jeff
Posted: Sat Aug 05, 2006 9:01 pm
by mtc
I moved my hound up the distance of the unit as would be calculated in a rt triangle Asq + Bsq = Csq with the unit's length being added to C.
Worked fine.
Have you dont this yet? I see that no one answered your post. There are a couple of these posted in the mod section, one from me.
Michael
Re: Foestay Quick Release Lever
Posted: Thu Apr 02, 2009 5:27 pm
by csm
Where did you find the QR lever at?
thanks,
Chris
Posted: Thu Apr 02, 2009 5:51 pm
by Hamin' X
Since this thread is over 2 years old and the OP has not visited the forum in over 6 months, I did a little sleuthing for you. By right clicking on the image and then selecting properties, it is revealed that the picture is hosted at
Defender. Going to Defender's website and doing a quick search for "Quick Release Lever" brought this to light:
Quick Lease Lever.(Their spelling, not mine.)
Posted: Thu Apr 02, 2009 7:32 pm
by csm
Rich,
U da cyber-sleuth man; thanks for the link
Chris
Posted: Thu Apr 02, 2009 7:40 pm
by Hamin' X
My pleasure. Perhaps it will be instructive to others.
Posted: Fri Apr 03, 2009 3:15 pm
by Mistral
Do a search for "Hifield levers" and there are several discussions on this in the forum.
Dirk
Posted: Sat Apr 04, 2009 12:01 am
by delevi
Just my personal opinion but forestay and quick release should not be in the same sentence.
Posted: Tue Apr 07, 2009 8:16 pm
by csm
Delevi,
Now that I actually have a boat, and have raised the mast, I have a much greater appreciation for your aversion to a quick release forestay. I'm pondering the benefits of a QR furler and a redundant forestay like "Matt 19020" posted under
http://www.macgregorsailors.com/forum/v ... 30#p148220.
Chris
Posted: Wed Apr 08, 2009 5:41 am
by pearl372
You can also purchase this device on the Kelly Hanson website. Regarding quick release, it is my understanding that the only thing released via the QR is a couple of inches of tension. The forestay remains connected until you remove the pin as per usual set up. Right? I haven't installed one yet but did just purchase from KH.
Rob
Posted: Thu Apr 09, 2009 12:34 am
by delevi
Wouldn't want that quick pin popping out under load. A few inches of sudden slack i.e. shock load while sailing or motoring at speed is potential for rig failure. Forestay slacks few inches, so do the shrouds. Wouldn't go there. Then you get into the complexities of shortening the jib or attaching the forestay higher (not where it was designed to attach.) What is the benefit anyway?
