Mast Falls - 26M
Posted: Tue Apr 17, 2007 9:19 pm
The rigging was up for three weeks, since taking the boat out of dry storage, and docked at a friend’s house at lake Harwell Georgia. We had some very gusty winds for a couple of days when my friend called and told me the mast had come down. The dock is in a protected cove but wave action could have played a part in this. I was on a business trip at the time and have yet to see the damage first hand. The good news is that nobody was hurt.
Let me apologize in advance if I do not use the correct terms here and for the length of this post.
I use a wire lock pin at the bottom of the fore stay; I have a roller furling. Evidently this pin worked loose because the locking wire was inadvertently disconnected when I washed the boat last weekend or at some other time, or it was not correctly installed when I rigged the boat. My friend says the locking wire was bent almost straight which to me means it temporally caught the weight of the mast when the pin came out.
My friend’s dock has a swim ladder that is about seven feet long and swivels up and locks in the vertical position to keep it out of the water when not in use. When the mast came down I’m assuming the wind pushed the mast to starboard so that it came to rest about fifteen to twenty degrees off the center line of the boat. Some of the rigging caught on the swim ladder and cushioned the fall; another stroke of good fortune because the mast came to rest, supported by the rigging, almost horizontally and only suffered “cosmetic” damage.
OK so you know I didn’t come out of this with out real damage. When the mast went over the side it twisted what I think is called the mast base hinge plate. Apparantly there is no damage where this pate attaches to the mast. There was no damage to the plate that attaches to the boat.
One of the spreaders is slightly deformed but no kinks.
Lessons learned: Inspect the rigging often. If I had done that last weekend after working on the boat this may have been avoided. I also think I will start using the head sail halyard intended for a hank on jib as a “safety” when the sail is not in use.
So here is where I ask for guidance and recommendations. I have read on this forum that a roller bearing assembly was available to replace the stock swivel arrangement for the mast on the M. Mine has really never worked very well, it tends to be either full left or right and when it changes sides it is with gusto, enough to think something broke. I was thinking that Blue Water Yachts offered this device and E-mailed an inquiry some time ago but did not receive an answer. Does anybody know if this device is still offered and if so who is offering it?
From reading many posts on this site I get the impression that the spreaders are some what tinder and that any spreader with any damage should be replaced rather than attempting a repair. I remember reading that someone was using stainless spreaders. Are they commercially available?
I have guests expecting to go sailing in about 10 days and need to find the quickest method of acquiring this or stock material as soon as possible. Any help you can give me in this regard would be very welcomed.
Thank you in advance
John
John
