Mast Cap Template
Posted: Sat Aug 04, 2007 7:47 pm
by ellsworb
This is a longshot, but does anyone have an outline drawing or maybe an engineer put together a CAD drawing of the outline of the top of the mast. I'm putting together my new mast cap and want to mount it similar to Tahoe Jack with an exact fit plug to screw in from the side of the mast. Thought I would ask here before dropping my mast.
Thanks
Posted: Sat Aug 04, 2007 7:59 pm
by Paul S
if it is an M, I am sure you can get a cap from Macgregor
Posted: Sat Aug 04, 2007 8:23 pm
by kziadie
A drawing showing the cross-section of the mast from the Macgregor website can be found here. Hope this helps.
Kelly
Posted: Sun Aug 05, 2007 10:07 am
by ellsworb
Wow, Good stuff. . unfortunately its for an X. . a 2000 :macx: . .anyone know if there's an online picture for the X mast?
Thanks!
Posted: Sun Aug 05, 2007 3:52 pm
by jasper
Dowsar Marine carries mast caps for pre- 2002 X's you can see it at
http://www.dowsar.com/options.htm
Posted: Sun Aug 05, 2007 7:05 pm
by Graham Carr
I have the cad drawing (PDF) for the 26 X mast and boom. The problem is I am working out-of-state, so I do not have immediate access to it. Call Bill from Macgregor, and he’ll be able to fax it to you. If for some odd reason he can not, let me know. I’ll have my wife fax it to me and then I’ll post it.
Graham
Exact fit
Posted: Fri Aug 10, 2007 1:43 pm
by vkmaynard
Posted: Fri Aug 10, 2007 5:29 pm
by ellsworb
yes thank you all. . i have all the supplies to do the project, but i was hoping to only have to lower the mast for INSTALLATION. . Hoping someone had a convenient CAD of the plug.
Thanks
mastcap for M
Posted: Wed Aug 22, 2007 6:15 am
by dannyboy
Kelly, I just replaced the mast on my 2005 M. The new mast does not come with a mastcap. I tried to use the old mastcap but it does not fit. The cross-section of the new mast is quite different than the old. Thought you would be interested....
Posted: Wed Aug 22, 2007 7:28 am
by LOUIS B HOLUB
I found a temporary fix for a "mast cap" -- alum. foil tape. Its good for a very long time, sticks well, and water proofs the mast. It trims easily, sticks well, and form fits exactly.
Ive used it for caps on pvc pipe for pasture electric fencing (keeping livestock), and the foil tape has lasted 3 years on some posts. It would probably last for years longer if not abused by livestock.
You'll have the shiney-ist mast cap in the harbor :P
8)
