IDA RUDDERS
- Bawgy
IDA RUDDERS
Just got my new rudders from Ida sailor . A tree fell on one of the old ones and gashed it up pretty bad so I ordered a new set . Hope they live up the good reviews I read about here.
- baldbaby2000
- Bawgy
Put the new rudders on this weekend . Will try them out at CLO this weekend . Pretty easy fix. all the holes were in my rudders but the travel lock holes didnt line up . The Rudder would hit the transom before the hole was fully exposed . About ½ the hole showed through the mount when the rudder was raised . I drilled two new holes instead of enlarging the old ones . I did not want the rudders to bounce up and hit the boat when towing
- baldbaby2000
- atzserv
ida sailor rudders
I called idasailor when i discovered the holes didn't quite match, they said drilling them out to fit was ok and didn't cause any integrity issues and that they would look into it, They seemed to think the newer Mac used the same size bolts as the actual bolt that mounts the rudders and that the older ones were just smaller.
gary
gary
- Bawgy
I didnot pay that much but they are very good rudders. I like the material and they do perform better. I busted mine so I replaced with the beefier rudder . I would not just replace to enhance performance because then where would it stop . Carbon Mast and Boom Detachable remote controlled dinghy with out board to follow around when racing. Carbon Sails . The list would go on
Yes the rudders are better but if you are ok with the Stocks Wait until you need one .
dancing_bear
- beene
Highlander and I got a set each. I had no issues with the holes at all. Just took off the stock ones, attached the IDA set, good to go.
Have been sailing 6 out of the last 7 days, was in a sailing race, logged several hours now.... love them! Much better at keeping my M on her feet. Tries to round up in a puff, with quicker response and more surface area, the IDA set hold her hard against the temptation to round up.
Best money spent on my M to date.
But you got them today !!!K9Kampers wrote:I'm not in the market for M rudders, but I've noticed this on the Kelly-Hanson Marine website:
Ida Sailor performance M rudders $699 / pair
Factory manufactured M rudder $95 each
I know it's apples v. oranges, but huh?....
k9Kampers then you should have got them in early Feb. before the price went up Beene & I paid less then $400./pair saved $300. each !!
