Anchor Locker Modification
Published date: April 27, 2000
  • Boat Type: Boat Type
I found it annoying that you couldn't close the hatch on the anchor
locker when you had some of the rode still in the locker. I ground
out a notch in the hatch cover so that the rode could pass through
with the cover closed. We have an anchor mount on the bow pulpit.
The hole is large enough that when the anchor is in the mount, the
chain part of the rode can pass through the hole.
In this picture, you can also see the guide for the furling line. I
mounted it where the directions said, but found later that it brought
the line into the furler a little bit low so that the line tends to
bunch up at the bottom when you have a lot going in and out, as we do
when using the genoa. Using the smaller jib, it works just fine.
One solution might be to mount it a bit further
aft. Just think about it before you start drilling!
Published by: Heath
Model Year: 1997
Share
Related Mods
  • Handy temporary anchor mount
    Anchoring - anchor (MacGregor 26S) - December 25, 2020
    Not exactly a mod, but an easy, effective, and inexpensive way to keep the anchor handy when you are planning to use it. A #8 anchor rests between the mast tangs at the fore pulpit, and is held in place with a short bungee cord. You will want to put ...
  • Anchor roller
    Anchor roller
    Anchoring - - December 1, 2019
    I mounted the custom anchor roller from Blue Water Yachts on "Sea Breeze." Works great and was not too difficult to install. The bow light is relocated onto a special bracket on the anchor roller. I had to extend (actually I replaced) the wire supply...
  • Anchor Storage
    Anchor Storage
    Anchoring - - November 18, 2017
    Figured how to put the anchor rode and chain in a cloth cooler in the little area forward of the v berth. It works nicely. The little cooler isn't waterproof but makes a nice filter for any gunk that gets on the chain so it won't flow into the bilge....
