Bow boarding ladder
Published date: January 26, 2008
  • Boat Type: Boat Type
Here are some pictures of my boarding ladder, this hangs on the side at the bow and takes adult weight quite easily
it stows on the rail and is out of the way
perfect for on the beach work
I bought this from Kmart for around $50 AUD, well worth it
Published by: CPT Haddock
Model Year: 2008
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • another Auto-Vent
    another Auto-Vent
    Miscellaneous - - December 13, 2007
    Here is another version of ballast tank vent for the 26X late model with vent under the vee berth. I couldn't find the Ace hardware type featured previously on this site but found a "flapper" valve in PVC plastic at a local farmer's supply that looke...
