Tiller Tender
Published date: July 14, 2008
  • Boat Type: Boat Type
When I added this tiller tender a bunch of work was taken away from my sailing duties. I still stand watch at all times but having the ability to move about the boat for short quick task sure makes it a lot more fun. Being tied to the tiller is a pain in the butt. I would advise all other sailors to do it.
Published by: CMikey
Model Year: 1980
Photo Caption: The Tiller Tender
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • Bow boarding ladder
    Bow boarding ladder
    Miscellaneous - - January 26, 2008
    Here are some pictures of my boarding ladder, this hangs on the side at the bow and takes adult weight quite easily it stows on the rail and is out of the way perfect for on the beach work I bought this from Kmart for around $50 AUD, well worth it Pu...
