Bilge Pumps
Published date: July 22, 2008
  • Boat Type: Boat Type
Having water in the bilge from time to time I decided to install a set of bilge pumps. I think actually one would need 5 pumps to get out the bilge water from all bilge compartments at once. However I decided that 3 pumps should be enough, one in the middle just behind the rudder and one each side in the rear between the ballast tanks. In the rear I installed two Johnson Pumps L550. After they are prepared (shortened) as shown on the picture they can be penned in between the bottom of the inner shelf and the bottom of the boat.
Published by: 2BonC
Model Year: 2003
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • Tiller Tender
    Tiller Tender
    Miscellaneous - - July 14, 2008
    When I added this tiller tender a bunch of work was taken away from my sailing duties. I still stand watch at all times but having the ability to move about the boat for short quick task sure makes it a lot more fun. Being tied to the tiller is a pai...
