Jib Sheet Angled Cleat Upgrade
- Boat Type: Boat Type
After sailing my new 26M a few times I found that the OEM installed Ronstan Cam cleats for the Jib sheets were not very easy to use as they were to close to the winch and the admiral was always fusssng to get the Jib sheet in, especially under heavier loads. I decided to replace them with Harken 150 cam cleats (get the aluminum ones) and an angled riser. I noticed that the Harken 150 have a rounded entry edge so the sheets slides in easier and I also installed the 15 degree riser kit (about $5 per cleat). You will have to fil the existing holes with epoxy and redrill them on an angle with the supplied drill jig. Altogether this mod only took a couple of hours and what a huge difference! The new Harken cam cleats rotate better, the sheets just drop in even under heavy load, with the angled riser we do not worry about the sheet coming out, and according to my West marine representative these aluminum cleats will far outlast the originals. Looking back, and knowing what I know now about the Harken 150 Cam Cleat, I may have just installed it as a direct replacement without the 15 degree angled riser - it may work very well with the easy entry leading edge and the supperior cleat design - but I am very happy with the angled riser too.
Published by: Cap'n Ahab
Related Mods
Quick Release PinsRigging - - December 1, 2019
We all hate to mess with clevis pins right? Try ball lock pins. I use 1/4 " x 2" pins on the boom/mast gooseneck connection, the tack of the main, and to fasten the roller reefing drum to the bow. Never had one come loose but I recommned using long p...
Elect Mast Raising 26xRigging - - November 25, 2007
I would like to share this mod, I have not used as yet, but I will. may be some time this week. I am using a 12 volt 3000 winch using wireless control remote, since most of the times I rig everything alone. I do not like makes holes in the fiberglass...
"Celtic" Downhaul for Hank-on JibRigging - - November 2, 2007
I wanted get better control of my hank-on jib when dousing it. In particular, I wanted to secure it completely from the cockpit without having to go up front and tend to it. I like the Dutchman flaking system for mainsails, so I came up with this as ...
