Mast rotating bearing
Published date: July 27, 2008
  • Boat Type: Boat Type
After installing new standing rigging one of the down sides was the mast refused to rotate in light winds this is what I have come up with. A standard wheel bearing pressed on to a manufactured spigot carrier bolted to the lower mast bracket, the outer race is tac welded to the mast upper bracket sitting on a conical washer (allowing clearance for the tapered bearing when mated) then covered with waterproof sealant (it looks a bit rough). The original bolt that joined the 2 halves was drilled out and a longer bolt inserted and tac welded in position. The entire race faces are coated with a liberal amount of grease and should last for at least 100,000 miles or 3 years if I can keep the rust out.
Jack Sparrow
Published by: Jack Sparrow
Model Year: 2007
Share
Related Mods
  • Quick Release Pins
    Quick Release Pins
    Rigging - - December 1, 2019
    We all hate to mess with clevis pins right? Try ball lock pins. I use 1/4 " x 2" pins on the boom/mast gooseneck connection, the tack of the main, and to fasten the roller reefing drum to the bow. Never had one come loose but I recommned using long p...
  • Jib Sheet Angled Cleat Upgrade
    Rigging - - July 27, 2008
    After sailing my new 26M a few times I found that the OEM installed Ronstan Cam cleats for the Jib sheets were not very easy to use as they were to close to the winch and the admiral was always fusssng to get the Jib sheet in, especially under heavie...
  • Elect Mast Raising 26x
    Rigging - - November 25, 2007
    I would like to share this mod, I have not used as yet, but I will. may be some time this week. I am using a 12 volt 3000 winch using wireless control remote, since most of the times I rig everything alone. I do not like makes holes in the fiberglass...
