faucet/spray nozzle
Published date: March 20, 2001
  • Boat Type: Boat Type
This is a standard spray nozzle like you find on a kitchen sink ($5 from Wal Mart). It comes standard with a 3/8 inch hose which hooked easily to the on-demand, 12v water pump I installed. The pump comes on automatically when the spray nozzle handle is depressed. It provides plenty of pressure for washing dishes or taking a shower. I have another nozzle installed in the head. The pump uses very little power. It costs about $70 from West Marine or $35 from J.C. Whitney auto supply catalog in the RV section. I bought a 15 gallon fresh-water tank from the same place. (See "water system" mods. for details on tank and pump) I have since improved the apperance by dressing up the hole with fixture flanges from the plumbing dept at Home Depot. Looks professional now. This is the best mod I made according to my wife.
Published by: coffeyd
Model Year: 2001
Share
Related Mods
  • Bilge pump
    Bilge pump
  • Faucet
    Faucet
  • Water tank and deck fitting
