Solar Panel Mounting Brackets
Published date: September 21, 2008
  • Boat Type: Boat Type
We have a love for electrical gadgets and the environment. So when a special on a 120W solar panel come up - I snapped it up. But where to mount it? I got some stainless tubing bent and then welded and bolted onto the existing rear mast support. I fitted a power socket on the stern, and ran the power cable through to the central power management area (the battery area under the stairs). It works very well.
I do not leave the panel mounted while trailering the boat - but lift it into the cabin.
Published by: rockman
Model Year: 2005
Photo Caption: Solar Panel Mounting
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • Bilge Pumps
    Bilge Pumps
    Miscellaneous - - July 22, 2008
    Having water in the bilge from time to time I decided to install a set of bilge pumps. I think actually one would need 5 pumps to get out the bilge water from all bilge compartments at once. However I decided that 3 pumps should be enough, one in the...
