Jib jam fix
- Boat Type: Boat Type
I find that the lower piston hanks on the jib can drop down prior to raising the sail and jam over the swaging on the forestay. To stop this I took a penny washer (SS of course) put a saw cut across one half, twisted it open and slipped it over the forestay twisted it closed and the jib hanks no longer get jammed. Cost.....next to nothing!
Published by: Pacamac-uk
Related Mods
Quick Release PinsRigging - - December 1, 2019
We all hate to mess with clevis pins right? Try ball lock pins. I use 1/4 " x 2" pins on the boom/mast gooseneck connection, the tack of the main, and to fasten the roller reefing drum to the bow. Never had one come loose but I recommned using long p...
Jib Sheet Angled Cleat UpgradeRigging - - July 27, 2008
After sailing my new 26M a few times I found that the OEM installed Ronstan Cam cleats for the Jib sheets were not very easy to use as they were to close to the winch and the admiral was always fusssng to get the Jib sheet in, especially under heavie...
Mast rotating bearingRigging - - July 27, 2008
After installing new standing rigging one of the down sides was the mast refused to rotate in light winds this is what I have come up with. A standard wheel bearing pressed on to a manufactured spigot carrier bolted to the lower mast bracket, the out...
