Closing mast gate for sail slugs
- Boat Type: Boat Type
I have fitted slugs to the mainsail to ease raising and lowering the sail. In order to stop the slugs falling out of the mast gate when reefed or sail lowered I needed to close the gate. I considered hammering it closed, fabricating a removeable gate and many other aborted ideas. I then saw an item in the UK's Practical Boat Owner magazine that had used a length of slotted alloy tube inserted into the mast, obviously done with the mast down. I used this idea but modified the method by using three short lengths of plastic tube, actually electrical conduit around 20mm dia. Each piece was slotted with a hacksaw and fixed into the mast gate with SS screws. The upper and lower remain in place and the middle section is removed to insert and remove the slugs from the mast. This has been in use all this season with no problems and was readily removed recently to decommission the boat prior to winter.
Published by: Pacamac-uk
Related Mods
Quick Release PinsRigging - - December 1, 2019
We all hate to mess with clevis pins right? Try ball lock pins. I use 1/4 " x 2" pins on the boom/mast gooseneck connection, the tack of the main, and to fasten the roller reefing drum to the bow. Never had one come loose but I recommned using long p...
Jib jam fixRigging - - October 14, 2008
I find that the lower piston hanks on the jib can drop down prior to raising the sail and jam over the swaging on the forestay. To stop this I took a penny washer (SS of course) put a saw cut across one half, twisted it open and slipped it over the f...
Jib Sheet Angled Cleat UpgradeRigging - - July 27, 2008
After sailing my new 26M a few times I found that the OEM installed Ronstan Cam cleats for the Jib sheets were not very easy to use as they were to close to the winch and the admiral was always fusssng to get the Jib sheet in, especially under heavie...
