water tank& pump
Published date: March 20, 2001
  • Boat Type: Boat Type
This 15 gallon water tank fits against the hull inside the gallet storage compartment. It is only about 10" wide so there is still plenty of room for the inserts to go back in and still store pots and pans inside the small door. The tank feeds an on-demand, low current draw, 12 v water pump. The pump automatically activates when pressure drops after the faucet is turned on. I use two kitchen-type spray nozzles, one in the galley and one in the head for quick showers. The pump cost about $35 and the tank about $30 from J.C. Whitney automotive supply catalog, or you can pay 2-3 times that amount at any marine retailer. I installed a plywood floor in the starage compartment in order to strap the tank down securely. The weight of the water tank on the port side will be offset by a blackwater storage tank and all the other food stores on the starboard side, and I plan to move the batteries into the bow. The port for filling the tank is in the side of the storage compartment so I didn't have to make any thru-hull cuts.
Published by: coffeyd
Model Year: 2001
Share
Related Mods
  • Bilge pump
    Bilge pump
  • Faucet
    Faucet
  • Water tank and deck fitting
