Electric Demand Water System
Published date: November 18, 2008
  • Boat Type: Boat Type
Added a pressurized/filtered water system. Uses a Jabsco Par-Max 2.9 50 psi pressure demand pump with strainer (1/2" model), Shurflo water faucets and Shurflo transom shower, Home Depot GE water filer with a Plastimo 26 gal flexible tank. Parts were mounted to inside the ice chest area (dead space). New 6 switch panel supplies power. The pump is mounted on a 1/2" Clark foam bulkhead stiffener glassed in place with 6oz bid cloth and a 9oz bid cloth pad under the pump (to reduce the noise). The two facets run off the water filter while the transom show is tapped off before the filter. Works great, more than quite enough and uses "dead space". Shower is next and nearly complete.
Published by: vkmaynard
Model Year: 2001
Photo Caption: Shower Sump
Share
Related Mods
  • Bilge pump
    Bilge pump
  • Faucet
    Faucet
  • Water tank and deck fitting
