Quasi Mac 33
Published date: January 1, 2009
  • Boat Type: Boat Type
I thought I would post my ideas here as I do not have a picture hosting site.
I moved the head forward as Duane wants it and fitted a nav station starboard aft of the table. Although, they could be swapped for a large head and small nav. The table is far enough forward to allow foot room and access forward of the compression post. I was just using the picture and eyeballed the dimension so it is not to scale.
Don
Published by: Don T
Model Year: 2010
Share
Related Mods
  • Drainage Holes
    Drainage Holes
    Miscellaneous - - December 1, 2019
    Here you can see the new lower drainage holes I drilled in the battery and gas compartments. The caulking in the compartment also needed to be redone since it had a few leaks which brought water and gas into the space between the inner and outer shel...
  • Boat Cover
    Boat Cover
    The full boat cover protects the boat against the harsh Australian sun. Without the cover the fibreglass becomes oxidised quickly especially the black around the windows. The cover is easy to put on with a zipper from the mast to the bow. I can do it...
  • Solar Panel Mounting Brackets
    Miscellaneous - - September 21, 2008
    We have a love for electrical gadgets and the environment. So when a special on a 120W solar panel come up - I snapped it up. But where to mount it? I got some stainless tubing bent and then welded and bolted onto the existing rear mast support. I fi...
