LED lights in aft berth
Published date: January 10, 2009
  • Boat Type: Boat Type
I acquired this 3 light kit(12LED each) at the local hardware store for 19.95$ because it was a 12 volt system which came with a 110v adapter and plug. I cut the adapter and 110 plug off and replaced it with a male cigarette lighter type plug which fits in my 12v outlet on the boat. The three lights were simply velcro-ed to the boat(the lights are plastic and very light)and the wires led through the existing boat seams as you can see in the pictures. Reading in the aft berth when on the hook is now a brilliant experience.
Published by: Qu├ębec 1
Model Year: 2003
Photo Caption: Wireing into boat seams
The 19.95$ light set
The set up
Share
Related Mods
  • Anchor Light and Windvane
    Lighting - - December 1, 2019
  • Light In Head
    Light In Head
  • Light in the headroom
